Use the following procedure to configure the minimum required SPBM and IS-IS parameters to enable SPBM operation on the switch.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#spbm Switch:1(config)#router isis Switch:1(config-isis)#spbm 1 Switch:1(config-isis)#spbm 1 b–vid 4051,4052 primary 10 Switch:1(config-isis)#spbm 1 nick-name 1.11.16 Switch:1(config-isis)#manual-area c0.2000.000.00 Switch:1(config-isis)#exit Switch:1(config)#interface GigabitEthernet 1/21 Switch:1(config-if)#isis Switch:1(config-if)#isis spbm 1 Switch:1(config-if)#isis enable Switch:1(config-if)#exit Switch:1(config)#vlan create 4051 type spbm-vlan Switch:1(config)#vlan create 4052 type spbm-vlan Switch:1(config)#router isis enable
Switch:1(config)#show isis spbm
                                                     ISIS SPBM Info
SPBM       B-VID      PRIMARY    NICK     LSDB     IP       IPV6     MULTICAST  SPB-PIM-GW         STP-MULTI  ORIGIN
INSTANCE              VLAN       NAME     TRAP                                                     HOMING
1          4051-4052  4051                disable  disable  disable  disable    disable            disable    dynamic
                                                  ISIS SPBM SMLT Info
SPBM       SMLT-SPLIT-BEB       SMLT-VIRTUAL-BMAC     SMLT-PEER-SYSTEM-ID
INSTANCE
1          primary              00:00:00:00:00:00
 Total Num of SPBM instances: 1
      Switch:1>show isis
                               ISIS General Info
                            AdminState : enabled
                            RouterType : Level 1
                             System ID : 0014.c7e1.33df
                  Max LSP Gen Interval : 900
                                Metric : wide
                   Overload-on-startup : 20
                              Overload : false
                         Csnp Interval : 10
                         PSNP Interval : 2
                     Rxmt LSP Interval : 5
                             spf-delay : 100
                           Router Name : Switch1
                     ip source-address : 41.41.41.100
                   ipv6 source-address : 41:0:0:0:0:0:0:100
              ip tunnel source-address : 11.11.12.11
                            Tunnel vrf : spboip
                         ip tunnel mtu : 1950
                     Num of Interfaces : 2
                 Num of Area Addresses : 1
                        inband-mgmt-ip :
                              backbone : disabled
              Dynamically Learned Area : 00.0000.0000
                            FAN Member : No
                         Hello Padding : enabled
                  Multi-Area OperState : disabled
                      Multi-Area Flags : home-always-up
                Designated BN Hostname : BN4435
          Designated BN Home System ID : 0010.7400.4435
        Designated BN Remote System ID : 0020.7400.4435
      Switch:1# show isis interface
                                ISIS Interfaces
IFIDX    TYPE   LEVEL    OP-STATE    ADM-STATE  ADJ  UP-ADJ  SPBM-L1    OP-SPBM-   ORIGIN   AREA   AREA-NAME
                                                             -METRIC    L1-METRIC
Mlt2     pt-pt  Level 1    UP         UP         1    1       10     (A) 10        CONFIG   HOME  area-9.00.02
Port1/21 pt-pt  Level 1    UP         UP         1    1       10     (A) 10        CONFIG   HOME  area-9.00.02
Home: 2 out of 2 Total Num of ISIS Interfaces
Legend:
(A): l1 metric is automatically updated based on detected interface speed.
    Variable definitions
The following table defines parameters for the isis command.
 Variable  |
 Value  |
 enable  |
 Enables or disables the IS-IS circuit/interface on the specified port or MLT. The default is disabled. Use the no option to disable IS-IS on the specified interface.  |
 spbm <1–100>  |
 Enable the SPBM instance on the IS-IS interfaces.  |
The following table defines parameters for the manual-area command.
 Variable  |
 Value  |
 <xx.xxx.xxx...xxx>  |
 Specifies the IS-IS manual-area (1–13 bytes in the format <xx.xxx.xxx...xxx>). Only one manual area is supported. For IS-IS to operate, you must configure at least one area. Use the no option to delete the manual area.  |
The following table defines parameters for the spbm command.
 Variable  |
 Value  |
 <1–100>  |
 Creates the SPBM instance. Only one SPBM instance is supported.  |
 b-vid {<vlan-id [-vlan-id] [,...]}  |
 Sets the IS-IS SPBM instance data VLANs. Use the no option to remove the specified B-VLAN from the SPBM instance.  |
 nick-name <x.xx.xx>  |
 Specifies a nickname for the SPBM instance globally. The value is 2.5 bytes in the format <x.xx.xx>. Use the no or default options to delete the configured nickname.  |
 primary <1-4059>  |
 Sets the IS-IS instance primary data B-VLAN.  |
The following table defines parameters for the vlan create command.
 Variable  |
 Value  |
 <2-4059>  |
 Specifies the VLAN ID. Creates an SPBM Backbone VLAN (B-VLAN). You can optionally specify a name for the SPBM B-VLAN.  |
 type {port-mstprstp|protocol-mstprstp|spbm-bvlan}  |
 Specifies the type of VLAN created.
Job aid
Important
After you have configured the SPBM nickname and enabled IS-IS. To maintain the same nickname with a different system ID, perform the following steps:
Disable IS-IS.
Change the system ID.
Change the nickname to a temporary one.
Enable IS-IS.
Wait up to 20 minutes for the LSPs with the original system ID to age out.
To check the age out time, use the show isis lsdb sysid <original-sys-id> command on any of the other SPB nodes in the network. When there is no output from this command, proceed to the next step. The time left (in seconds) for the LSPs to age out is shown under the column LIFETIME.
Disable IS-IS.
Change the nickname to the original nickname.
Enable IS-IS.
